Im going to be getting an Abit IP35 Pro and i plan on pushing it to its fsb limits. In order to get the most out of it I am looking to put an aftermarket NB cooler on it if i can't reach my goals of 500+ fsb comfortably.
I have been looking around at NB coolers and I have found that the HR-05 seems to be the best bang for the buck. On thermalright's website I don't think they officially support it. However, my brother has gotten one of these for his mobo which "wasn't supported" according to a rep, and he said he managed to get it to fit and function perfectly.
Can anyone tell me if they have had experience with aftermarket NB coolers for their p35 boards and what you used if you did? Also let me know what kind of difference it made in temp.
Thanks,
Thanks,
