- May 26, 2007
I'm looking to get some advice on my p182 fan layout. At the moment my setup looks like this, arrows show the direction of the fans.
So i'm not sure if i should have my cpu fan/heatsink blowing out threw the top or blow it out the back and re-reverse the top fan to blow back out which i have it blowing in the case. My temps right in Pc wizard are Cpu temp : 45c, Core 1 : 45, 2 : 45, 3 : 42 amd core 4 : 43.
I have a q6600@2997, vcore 1.296 and HD 4870 with fan at 26 with the gpu at 62c. Any help would be nice, thx. P.S When i look at my temps what is the important ones to look at, the cpu temp or the cores 1-4?
So i'm not sure if i should have my cpu fan/heatsink blowing out threw the top or blow it out the back and re-reverse the top fan to blow back out which i have it blowing in the case. My temps right in Pc wizard are Cpu temp : 45c, Core 1 : 45, 2 : 45, 3 : 42 amd core 4 : 43. I have a q6600@2997, vcore 1.296 and HD 4870 with fan at 26 with the gpu at 62c. Any help would be nice, thx. P.S When i look at my temps what is the important ones to look at, the cpu temp or the cores 1-4?
