P180B problems
osok11
How am i supposed to hold the dvd-roms in place? theres nothing for it to be in place
there should be some click thingies you screw onto the sides of the drive to hold it in place, look in the manual you'll see what they look like...
Ok, the case should've came with with the drive rails you need to attach to the optical drives. Read the manual for more info.
The drive rails are the grey plastic pieces with the metal (chrome) ends, put one on each side of the drive and insert into the drive bay. There should be 6 or so for the 5.25 drives and a couple for the 3.5.
