satriani5902
- Jul 19, 2004
My Antec P180 came with only 3 brass standoffs, is that normal? Seems like I will need more. Or do I not need them? There seems to be some standoffs that are soldered onto the case.
satriani5902 said:My Antec P180 came with only 3 brass standoffs, is that normal? Seems like I will need more. Or do I not need them? There seems to be some standoffs that are soldered onto the case.
theclone said:My P180 came with three brass standoffs and the case had three holes where you could screw them into . . .
DudeItsMe said:The P180 manual said "extra" standoffs that your motherboard doesn't use wouldn't cause a problem. Either way, I used all of mine.
I think mine came with about eight pre-installed, and plenty extra. This was from Newegg on 6/6/06
