P180 mod/prep advice
AC!D-RXN
Hey guys,
I just bought a P180 and I want to make it perfect and silent.
I am wondering if anyone has suggestions on what to do:
I am thinking:
- cut holes to route cables (where/how?)
- paint the inside black (Anyone have advice on how best to do this?)
- sound proof padding
Thanks all
i just painted the inside of my Lian-Li white. it was very easy (i had no experience too). i wanted a flat color to it so i didnt do intensive sanding or anything.
painting the inside of your case reallly gives it a great look. i wouldnt suggest black, just because its so over done.
White interior is cool because it really enhances any color you put into your case, especially UV.
Moddest Mouse, can you post a picture of that? or link me if you already have somewhere, im intrested to see that, thanks!
can someone tell me the correct procedure for painting the interior of a case?
Thanks!
