P180 Mini- Triple Rad + Full Coverage GPU Block...Pics
TheScavenger
Here it is at about 95% complete...
- The middle and right rad fans are 120mm x 20mm Yate Loons
- The top of the hard drive cage has been ventilated to allow proper airflow to the rad fan above it
- I plan on putting an exhaust fan on the rear of the case but I need a couple 45 degree fittings for the rad first
I'm in the process I devising another layout for my gpu-output to reservoir-input tubing. It's probably going to involve a couple weird adapters. Let me know if you have any questions or comments :D
Holy tube crimping! Otherwise nice use of space! ...And I thought I was clever in watercooling my entire board and CPU with two-320s and a 240 radiator in my Antec 1200.
Nice build. I am starting a build in the same case. If i go with water cooling, I am going to use the Koolance res/pump combo that slides in a 5 1/4 bay. It consolidates everything very nicely. I used them in the past and never had one issue with them. Temps were good too.
