i got my 3800+ today, and after the first boot clocked it up to 2.5ghz, booted into windows fine, everything stable... so i reboot, try and find the max clock i can boot at... i can boot all the way up to 2690(269x10 of course), but not 2700... but its only stable at 2.5ghz... even at 1.6v i can't get over 2500 mhz... is there anything i'm not taking into consideration? i know my board can handle 320 mhz fsb/htt, and my ram 208mhz(running at pc2700 speeds at 2500)... would me having to run a beta bios to have the x2 recognized have any effect on it? my temp's seem fine, i'm only hitting 49C@100% load on both cores, mid 30's at idle(water cooled)... heres the info on my proc
ADA3800DAA5BV
CDBHE 0535SPMW
i haven't seen any other week 35 oc info, so i don't know if what i have achieved is to be expected, but i know that some of the fairly close weeks are hitting higher than i am, and the water cooled ones seem to be hitting around 2800, where i had my venice clocked to... i'm at work right now so i won't be able to do anything with this now, but any suggestions?
ADA3800DAA5BV
CDBHE 0535SPMW
