Overclocking without a hard drive?
delvryboy
Is there a way to make a boot cd with prime95 or orthos?
I want to make sure my occ and temps are good. Should I just use a hdd that is loaded w/ Unbuntu and core temp/speedan/cpu-z/prime95 and use it for every boxen I build?
The second option would probably be the easiest. I think the first would be doable just would have to create a custom CD/DVD
You could probably use a usb key for the second option to make it easier. UltimateBootCD has prime, but unfortunately it doesnt do multicore.
Actually, I'm having fun playing with Unbuntu on this old P4, but the hdd is coming out in a few days.
I think I'll run an x64 linux on the quad folding boxen I'll be putting together just so I can get some more experience.
