What's a good combo for AM2. I just realized that since i just got my new mobo, CPU, and another mobo (which is being sent backbecause it's broken) I can send all 3 of them back and get around $200 for them.
I'm going to try to figure out what a good AMD AM2 CPU is for overclocking. I have sufficient cooling with my Zelman 7700. My 4200+ (939) gets about 40c with a load. I also have a 600w PSU so power shouldn't be a big issue.
This CPU/Mobo will cause me to get more ram because all I have is DDR 400 (PC 3200 I think).
If possible, i'd like this mobo to be able to support the 2 fans i have in my case that must plug into the motherboard. My old ASUS A8N5X had a 3 pin Sys Fan right behind the USB ports on the MoBo and another one right up front. That would BE PERFECT for me if you can find one that fits the above requirements but as long as it has one 3 pin connecter (besides the CPU's) it should be fine.
What these will be used for:
-Light Overclocking by a person somewhat new to overclocking
-Gaming
-The regular stuff: AIM, XFire, Graphics, Music, Movies, ect.
Please find them on www.newegg.com if possible becuase I usually always order from there.
Thanks.
-Gaming
Thanks.
