Hi all, I just recently upgraded to the Athlon64 X2 3800+ (after finding someone to buy my currect proc that is in my signature). Anyways, I had an Athlon64 3000+ (old vore, not one of the new Venice ones), and it overclocked just fine to 2.25GHz. by dropping the HTT mult from 5 to 4, and then just upping the HTT bus to 250. I have DDR500 memory, so that was running to spec as well. When I bought the Athlon64 X2 though, I seem to be struggling a bit. I never changed the voltage or multiplier before, just the bus speeds and multipliers.
So yea with this new proc, I had to upgrade the bios before it would even boot any decide (it would post fine, but it would hang when it should boot off the CD drive or hard drive array). I finally got the bios upgraded, but I am still having OC problems. It is running stock right now with the DDR500 option enabled (using the new memory controls in the CPU). I tried upping the voltage a little bit, and I even tried adjusting the multiplier down to see if I could increase the HTT speed still, and that didn't help. So this makes me wonder if my chip is just reluctant to change speeds, or if it is the motherboard not OCing as well with the X2 chip? I was able to increase the HTT speed to about 208 or so with the system still booting, but I didn't test it for any extended period of time at that speed. Thanks for any help guys,
Jason
edit -> The motherboard is the Gigabyte K8N Ultra SLI
Jason
