I'm building a new PC and will definitely be overclocking it (will be using Vista-64, if that matters for this thread). Due to a recent deal, I already bought the mobo/cpu (but I will be getting the cpu cooler and RAM at the very beginning of November. Anyways, here are the parts I already have:
Motherboard: GIGABYTE GA-EP45-UD3P LGA 775 Intel P45
CPU: Intel Core 2 Duo E8500 (E0 stepping)
And here are the parts I have yet to get (as far as this issue of overclocking is concerned):
CPU Cooler: Sunbeam CR-CCTF 120mm "Core Contact Freezer"
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000)
I read some reviews about the cooler, and it looks fairly solid so I'm fairly confident about my choice there. I'll be combining it with Arctic Silver 5.
I'm not sure about the RAM though. With the mobo/cpu/cooler in mind, will the RAM I listed (DDR2-1000) be fast enough for my intentions, or would I be better off within something faster? Can you recommend something better, or will I do just fine with that set? I'd really like to stick with 4GB (2x2GB) as far as the amount of RAM I get, and my budget is about $150.
