twonunpackmule
- Sep 27, 2005
Okay, I'm currently trying to maintain a stable 3.8 overclock with my i7 930. I think I hit it, but am trying to figure out a few problems.
My specs are as followed...
i7 930 with Corsair H50 - Stock Fan, new fans on order...
6gb of DDR 3 Corsair XMS RAM
X58A-UD5 rev 2.0
2x 64gb Corsair SSD
2x 1tb Western Digital Blacks
EVGA 460SE 1gb SLi
HAF X PC Case
Anyway, the issues seems that it stumbles a bit before it will POST. The power light blinks a few times and then powers on, with a single normal POST beep. If I go back to stock settings, it does not stumble.
I've read many different things that it could be. Some say it's normal part of the process and that the hardware is just "making sure." It's a safety feature.
I've also read that it could be faulty ram. Or a voltage issue.
I've checked my ram with Memtest and Prime seems to be alright.
I'm currently doing another Prime pass with the start settings at 1280k. I was going to let that run for at least 3 hours.
X58A-UD5 rev 2.0
2x 64gb Corsair SSD
EVGA 460SE 1gb SLi
HAF X PC Case
