Overclocking help needed
SocceRich20
Hello,
I have the following
-2.8C
-IS7
-2x 512MB Kingston HyperX PC4000
-ATI Radeon 9800 Pro
-Zalman CNPS-7000Cu
Right now I have it running at the stock 200 fsb, at 1:1. All settings are are default now, voltages and such. What would be my best bet to try to reach 250fsb. About what voltages for the ram and cpu would be right? I heard that Abit boards undervolt the ram. Any help is appreciated. Thanks.
the ram is good for DDR500 which is a 250fsb, so whatever the default voltage is for memory, you shouldnt need to raise it. you might want to bring it up one notch just for the heck of it. im not to sure about CPU voltages on the 2.8c. i would start off at 1.65v, and work your way down on the voltage. people usually start the other way around, but i find it easier to troubleshoot when going from higher voltages down to lowest stable voltage.
