GreatestOne
- May 15, 2005
Overclocking Factors Hierarchy
Ok, I want to compile some type of meaningful list that
includes all the components of a successful max
enthusiasts/gamers overclock for a CPU in the order of
importance. My guess is down below and then I have
some questions as well. All corrections and answers are of
course appreciated.
- CPU type
- Motherboard type
- Cooling system
- Voltage Settings
- Memory/RAM type
Questions:
- Is the max stable voltage setting directly related to CPU heat
or is the responsibility equally shared between all the above
components? I.e., if your CPU is running say under 60C even
on heavy load, is there any reason you cant go higher on the
voltages, I guess mostly the CPU Core/VTT Voltage.
- How important is the NB/SB cooling/voltage settings, and how
many of you have found needs to find better cooling solutions
for those components (aircoolers only of course)?
course appreciated.
- CPU type
- Motherboard type
- Cooling system
- Voltage Settings
- Memory/RAM type
Questions:
