so i have a ref r9 290, i keep messing around with voltages upto +300mv sometimes, clocks not so much but memory 1600mhz or so just out of curiousity.
Normally i run my card at stock to +19mv on 1000/1500, but i sometimes like to benchmark with 100% fan speed with retarded clocks and voltage.
i have done benchmarks with artifacts (started artifacting in the start but i still let it finish) to see how clock speed affects.
I mostly do unigine benches.
My question is, can this break something? i've made it crash over a 100 times due to too high mem on too low volts - pretty sure.
or can overclocking / messing with volts break cards at all? aren't there limits imposed so that no matter how much u play with your clocks, card will just shut down and be ok.
EDIT : i also have flashed different bioses 100+ times.
