I have an Asus A8N32SLI with a 3800X2 E6 stepping processor in it. I have the FSB set at 250, NB to CPU 4x, NB to SB 5X, I have all settings on manual except for the ram delay which is on auto. Right now it is at a 300 delay which it was at before. I just changed my ram from OCZ 400512ELPE to OCZ5002048EBPE-K.
The problem I am having is before I could run my system at 252 FSB with 10x mulitplier and ram set at 166mhz setting for a ram speed of 210. Now I have my ram set at the 200mhz setting because of running 500mhz ram. The issue I am having is I no longer can run at 252 mhz fsb. I can an only run at 250 mhz fsb. If I try booting at anything higher the comp locks up and I have to flip the power switch on the power supply off and then back on. It reboots and says bad overclock.
I know I am now running the memory speed into my processor at 500 MHZ instead of the designed 400 MHZ. But I have seen people with 533MHZ in the same system and I am sure they are running a fsb frequency close to that or why that high of memory. Does anyone have any idea why I would be getting capped at the exactly 500MHZ?
