supremeone
- May 17, 2007
Hey, I got a gigabyte p-35 ds3l board and a e2160 intel cpu. Right now the processing speed is at the default of 1800mhz. But it varies from 1200mhz to 1800mhz. And I got a xigatech heatsink.
Anyways I tried overclocking in the past but unfortunately like i got to 2.4ghz than 3.0ghz, while raising the vcore. Think I ran prime 95 for a few hours too when doing it. But I think I might have got somewhere around 1.38 vcore or less at 3.0ghz. Anyways pc turned off like 2 or 3 times after 6-8 hours each time. And than pc stopped booting up completely. I cleared cmos a few times, and did something else. But it was weird like when it booted up, it would turn off fast, idk, but it was better when I put all settings back at default. Now I should also mention when i installed my mobo back than I didnt use standoffs, just some metal screws, some how it propped the board up enough that it worked. It's fixed now.
So I'm wondering, should I be worried about trying to overclock it again, maybe to 2.4 ghz and see how it goes? I heard you can go to 2.2 or 2.4 ghz on a e2160 without increasing the voltage. I don't want cpu to break or something or not boot up anymore ;\ Kinda paranoid about it since last time I tried to overclock, it seemed like it was dead.
