Overclocking 4-way SLI
Snigle
Hello,
I have a 4-way SLI setup (Asus GTX680-2GD5) which I have been using the provided GPU Tweak utility. This is the first major upgrade I have had in years.. so I have two questions.
1) What is the best tool(s) to overclock a GTX680 4-way SLI setup?
2) I read (in another post) that you will get better performance overclocking each card individually. Is this true? And how (or where in the software) can I do this?
Any suggestions or guidance would be appropriated! Thanks!
I would just use ASUS GPU Tweak utility. It's supposedly pretty good.
I have two-way SLI with 680s and I am using EVGA Precision X as well. That's also a very solid tool.
I wouldn't bother to overclock individually. It'll take you way too much time to find each card's specific maximum stable overclock. Just overclock all four in sync and be done with it.
