Syphon Filter
- Dec 19, 2003
Hi guys...i have the following bits:
Abit IC7-Max3, 2.8C P4 and 2moro i will have 1gig of corsair XMS4000 dual channel kit RAM.
I am cooling with just air for the time being...what i would like to know is what BIOS settings should i use to get the most out of that setup...
I plan to run the CPU at stock voltage, and up the FSB to 235 at least...higher if temps dont become a huge problem (which they shudnt if i am running at stock voltage right?)...what kinda settings should i be looking at for DDR voltages and anything else? Also will i be able to set my RAM timings aggressively with that RAM? Any other tips and info would be much appreciated, i am not a total newbie but would like to brush up before i start messing around again...
Regards,
Syphon
Regards,
Syphon
