overclck q6600 965p help
http://www.hardforum.com/showthread.php?p=1030795318
The bios settings in the above guide should get you started.
try 400 FSB x cpu mulit of 7 with memory at a 2.0 divider for a 2.8GHz OC to start and then work your way up by raising the FSB. At some point you will want to go to a mulit of 8 and FSB of about 375 = 3.0GHz and work up from there.
Make sure you put in your memory voltage and timings. its all in the guide.
Ask any questions you may have in the quide thread.
