I have recently connected my pchd 3000 card on my HTPC backend box to my Winegard squareshooter antenna inside my condo. I've gotten some really puzzling results when I scanned for channels. Here is the dumped service list that the card found:
I'm having some trouble understanding the output. Discovery, TLC, Lifetime, Starz, Disney, Cartoon network??? From an antenna? Stranger still is that these channels are actually tuneable and I can get the tuner FE to lock on them pretty well:
Once the tuner is locked on to this signal, if I bust out mplayer I get crc errors in the stream, or mplayer isn't able to find a stream in them at all. Am I actually pulling an encrypted signal off of my neighbor's cable? Any other ideas? Anybody live in downtown dallas that also is able to see these channels OTA?
-confusedq
# atscscan /usr/share/dvb/atsc/us-ATSC-center-frequencies-8VSB
...skip the scan output...
dumping lists (15 services)
KTXA-DT·:497028615:8VSB:49:52:1
KTXA-DT·:497028615:8VSB:65:68:2
KMPX-DT·:569028615:8VSB:49:52:1
DISC:569028615:8VSB:257:260:16
TLC:569028615:8VSB:273:276:17
LIFE:569028615:8VSB:305:308:19
STARZ:569028615:8VSB:945:948:59
KDAF-CW33 Digital:581028615:8VSB:49:52:3
The TUBE:581028615:8VSB:65:68:4
[0003]:605028615:8VSB:49:52:3
DISN:605028615:8VSB:209:212:13
TOON:605028615:8VSB:225:228:14
KXTX DT:629028615:8VSB:33:36:2
KXAS-DT:635028615:8VSB:49:52:3
KXAS-SD:635028615:8VSB:65:68:4
Done.
# azap -r DISC
using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0'
tuning to 569028615 Hz
video pid 0x0101, audio pid 0x0104
status 00 | signal 3999 | snr cd37 | ber 00000000 | unc 00000000 |
status 1f | signal 28f5 | snr cd37 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 63d6 | snr cd03 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 44dc | snr e22b | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 3a9f | snr eb37 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal ac8a | snr f815 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal ac8a | snr f80f | ber 00000000 | unc 00000000 | FE_HAS_LOCK
-confusedq
