Sorry, fdd?P3N1X0R said:do you have the sata drives on a fdd and hit f6 when the windows install says it
Zero said:I've been told by a friend that Win XP Pro can have issues installing to SATA drives on a brand new machine.
Anyone back this claim up and if I do encounter it, what's the fix?
brom42 said:This completely depends on what motherboard you are using and where you are plugging them into. Please give more system info.
Zero said:I don't actually have this yet, it's coming in tomorrow or Friday, but I was just trying to anticipate any problems. The motherboard I'm getting is the Abit Fatal1ty AN8-SLI.
As for floppy drives, I didn't get one with this system. Is this a problem?
brom42 said:You have 2 options.
Option 1(Not using raid):
Plug hard drives into NF4 SATA and install windows, no drivers or anything needed. Everything works perfectly.
Option 2(Using Raid):
Press F6 when prompted. You will have to install the NF4 IDE drivers off a floppy disk. Just grab the one from your old computer or borrow one from a friend. Install drivers off of disk. Install windows normally.
You should have no problems either way. I have set up quite a few NF4 board in both raid and non-raid configurations using these methods.
Zero said:I plan to RAID1 this machine eventually once I order more HDs(it has 1 now, I'm getting 3 more in about a month). Does this make a difference in how I install windows now? Or can I change this later? (never set up RAID before)
