OS Install issues - Vertex2 on EP35-DS3P
AshleyG
I've spent a good amount of time researchng a fix as to not waste everyone's time here, but my frustrations have hit a tipping point. System details are at the bottom..
I first installed the drive as a secondary drive for prepping. Using OCZ toolbox, I updated to firmware 1.23. I then did a Secure Erase. My system had no difficulty recognizing the drive either before or after these steps. It is purring along fine right now as an application drive.
I bought the drive to replace my aging Maxtor Maxline III as a boot drive; it's the loudest thing in my system by far. After confirming that the drive worked and setting it up as the only SATA drive attached to my system, I made sure to clear the CMOS and set it as the first drive in the BIOS in both locations. I changed the RAID setting to AHCI and dropped the appropriate drivers on a second thumb drive just in case. Here's where things get funky.
The PC makes it past the POST and begins booting from my Windows 7 USBdrive. When it started to load the OS, I noticed that the white bar is filling up really slowly - much more so than any hdd install had gone. It finally gets to the Upgrade/Complete/Other page and I choose to install a new OS. The drive appears in the list - no issue there. Any attempt to do anything hits a brick wall. Going forward, I get the message that the computer cannot do anything with the drive (something about partitions, etc - things I'd taken care of earlier, I thought). I try loading the AHCI drivers from my driver USB; the drivers load right away, but I still can't move forward with the install.
Long story short, despite following instructions found through Google and at the manufacturer's site I just can't seem to install Windows 7 to this drive. it's working great as an app drive, but that's not why I bought it. I really don't want to send it back but I fear I may have to. I'm willing to give any suggestion a go that the gurus here recommend.
Thanks for your help.
System:
Gigabyte EP35-DS3P F5; Intel Q9300 @ Stock
8GB (4x2) Corsair DDR800, EVGA GTX460 OC 1GB
Corsair HX620W PSU, Maxtor Maxline III 250GB HDD
Shouldn't your USB with the W7 install be the first boot drive on the list?
You won't need any drivers for a W7 install.
There's no difference between a mechanical drive and an SSD when it comes to installing an OS.
If the BIOS sees the drive and your having install problems with an SSD, you'd have the same problems with a mechanical HD.
Got it fixed. I was letting W7 Setup delete the partition on the drive, which then was not allowed somehow to recreate it or create another. I reformatted the drive in Windows, swapped out the drives, and told W7 to install in the partition that was already there. Viola.
Convoluted, if you ask me.
