Ok,
For all that think Orthos run for any long amount of time proves a system is stable take this into consideration. I have my overclock at 3.5ghz and it is orthos stable for 24 hours and I have run 3dmark after the orthos run too. I go to play Supcom lastnight and load up a 8 player supreme AI map and play to see just how stable it is. Game crashes 4 times, granted its about an hour into the match and there are a lot of units. O kept upping the voltage but it seemed to crash still, I also ran orthos again (blend pri 9) and it didnt crash. So where do you guys think the problem is? When I looked at the error report for Supcom it mentioned direct X so I am thinking it has something to do with the video card. Another thing that makes me think its the video card is when I try to go for 3.6ghz orthos runs and superpi runs but 3dmark will not run. So does anyone have any ideas? Maybe the info is having trouble going through the PCI bus? who knows.
Thanks,
Eddie
Thanks,
Eddie
