Ordering in two days...and can't decide between these two.....????
Bad Goat
On the fence between the Asus A8N-SLI Deluxe or the MSI K8N Neo4 Platinum-SLI. I am also getting a A64 3500+ (Winchester), and eVGA 6800GT. But the mobo is giving me the biggest problem. They are both great boards from what I have seen just can't make up my mind. Suggestions would be great. :confused:
Also, I have the Antec TrueBlue 480W PSU. Will I have any problems running this PSU with either of those mobos? Plug configuration? is there an adapter? 20-24pin? Any other things I need to be thinking about??
*bump*
Ok.....now I am ordering tomorrow morning....crunch time here fellas. Could really use some input
Personally I prefer Asus over MSI. But there are some overclocking issues with the A8N-SLi. They are supposed to be addressed in an upcomming BIOS update, but that remains to be seen.
QFT
I like asus myself [see sig] but it seems to me that for your setup, the MSI is considered to be the better choice.
I just got this weekend the MSI, 3800+ and the eVGA 6800GT. EVERYTHING I read as far as PSU's goes says for stability get a 24pin PSU. It should work fine, but no one was really keen on the idea. I went and got the Antec NeoPower 480. It does not have the -5v line (which the onboard SB chip needs) but I am using my Audigy2ZS anyways.
Ordered mine from Monarch, MB, CPU, and memory all setup and tested, delivered.
How high do you wish to OC at the default multiplier?
The Asus A8N-SLI gets stuck at 250mz. That's why they're coming out with the new version which is supposed to address those concerns.
Neo4 SLI has been a good board for me. I run 9x267, which I'm not sure would happen on the A8N-SLI right now.
First, that psu might not work with the Creative onboard sound due to the -5V requirement. That's something you'll have to look into. It says in the specs it has a -5V line, so maybe you're ok there.
Second, I'm pretty sure that's a 20-pin psu, so it will work, but I'd look into getting an adapter ($7-10).
Third, a mild OC isn't that hard to do...give it a try :cool:
With 1002 bios my A8N has given me 0 problems.
Overclocks to 210fsb with 0 problems.
I had mine up to 264mhz but got hd corruption.
Currently I'm only overclocked to 206fsb because I am running a 350watt 20pin HEC ($40) power supply. If nothing newer/better for around $100 comes out by end of this month I will prob upgrade to a Fortron Blue Storm 500. My current psu peek is single 15amp 12v rail, where the blue storm has two 12v rails at constant 15amps, 18.5 peak from what I hear.
I'd definitely wait on the ASUS until the premium version comes out.
you should get the Asus A8N-SLI Deluxe, because asus has made some pretty good motherboard through out the year, they also have a good reputation for making motherboard.
