Ordering in 12 day input would be nice
Jbort1984
Ok well w2 finally got here and i will have my money in less than 2 weeks. So Ive set aside about $2000 to build a new tower and this is what ive comes up with.
NZXT Phantom PHAN-001WT White Steel / Plastic ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067 $139.99
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185 $64.99
2x ASUS ENGTX570/2DI/1280MD5 GeForce GTX 570 (Fermi) 1280MB 320-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121412 $699.98
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009 $129.99
2xG.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 1066)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231417 $169.98
ASUS P8P67 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131681 $159.98
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 $224.99
LG Black 10X Blu-ray Burner - Bulk SATA WH10LS30 LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136181 $99.99
Crucial RealSSD C300 CTFDDAC128MAG-1G1 2.5
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148348 $264.99
This computer will be used for Hours and hours of gaming everything from racing fps and mmorpgs ( yea i play world of warcraft alot have 5 lvl 85s). I will also be doing alot of burning blu ray backups for my own collection and putting alot of home movies onto bluray disk or dvd for family members. Music recording and editing on some scale not shure how much yet and some photoshop and 3d modeling when im bored.
Have $2000 max
3) Where do you live?
Syracuse ny
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
Going to need mobo,cpu,ram,video card(s),hdd,case,psu
Only thing im keeping is my 2x32in lg monitors and my 42in samsung monitor all run 1920-1080 resolution. And my xfi fatality edition sound card + Bose companion speakers.
6) Will you be overclocking?
I would like to oc just the cpu to 4ghz
2x32in 1x42in
Within the next 12 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI
support? USB 3.0? SATA 6Gb/s? etc.
Would like sli sata 6gb and usb 3.0
Reusing windows 7 64bit ultimate edition.
Dunno how you're geting that Vertex 2 120GB for $100. Mistype? Assuming that's a mis-type, ditch that SSD and go with the faster Crucial C300 SSD:
$265 - Crucial RealSSD C300 CTFDDAC0128MAG-1G1 2.5" 128GB SSD
You can get this equally fast hard drive for $10 less:
$70 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
RAM wise, unless you really want fancy heatsinks, you can save about $12 by getting two of this set of RAM:
$78 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
Ditch that power supply as it is overpriced for the amount of amperage it provides. Go with this slightly more expensive PSU instead:
$136 - Corsair 850TX 850W PSU
It has more power on the +12V rail than that CP-850 PSU which means that it'll better handle GTX 570 SLI.
Ditching that above Antec PSU lets us ditch the Antec 900 case as well: The Antec 900 case is a horribly cramped case for the price. There are roomier and equally if not better cooling cases out there for around that price range:
$80 - NZXT Tempest Evo TEVO-001BK ATX Case
$80 - Lian Li Lancool PC-K58 ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$100 - Lian Li PC-60FN ATX Case
$100 - Lian Li Lancool PC-K7B ATX Case
$110 - Lian Li PC-7B Plus II ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
Your correct i did change out the ssd case psu and hdd from your suggestions thanxs for the input
