Optimum memory for FAH
RPhArrow
The last 3 P4 hyperthreaded boxen that I started with FAH, I put 1 GB of RAM into (all linux)... just thinking that if I was running 2 FAH processes the RAM would get used. Now , looking at RAM usage, it's only 250MB tops on any of those boxes. It appears I am wasting my RAM ...
How much ram are y'all using in each box (considering cpu & os ) ?? And what do you think is optimum ?
I have 1GB in my main rig... a P4 2.4C OCed to 3.0.... I have big packets enabled on both threads..... it can definately take a chunk of RAM... I've seen it as high as 400MB for each.....
Keep on Folding!! For the [H]orde!!
One thing to keep in mind however, is not just quantity of ram, but the amount of memory bandwidth available. If you're running two sessions of big WU's you can see a major slowdown just because the ram can't swap fast enough.
The normal suggestion is maybe one client running normal units, and the other running big as not to chew up all the bandwidth.
