Optimizing Gaming
Hi- I built this system last fall,but made a few upgrades.I replaced my GTS 250 for GTX 460 and upgraded the monitor.Here are the specs.
Antec 900
ASUS VH236HL-P Black 23" 2ms(GTG) HDMI Widescreen Full HD 1080P LCD Monitor w/height & swivel adjustment 300 cd/m2 ASCR 20000 :1
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor
GIGABYTE GA-MA790GPT-UD3H AM3 AMD 790GX HDMI ATX AMD Motherboard
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ - Retail
EVGA 01G-P3-1373-AR GeForce GTX 460 (Fermi) Superclocked EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm -Use 2 fans for push and pull. CPU idles at 27 degees celsis.Load 38-40.
CORSAIR 650W
(2) LITE-ON 24X DVD Writer Black SATA Model
Rosewill RC-401-EX 10/ 100/ 1000Mbps PCI-Express Gigabit Low Profile Network Card - Retail
(2) Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
(1) Western Digital Caviar Blue 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive
I also run a dual boot for using xp 32 bit and windows 7 64 bit.I took (1) of the 750G HDD and partitioned it into 3 drives.40gigs/80gigs,and the remainder 580gigs for storage.I use the 40gig for xp,the 80gig for 7,and the remainder 580gigs for storage.I have 2 other hard drives.A 750gig,and a 320gig.I partitioned the 320 gig drive into 3 drives.5gigs/5gigs,and remainder storage.I use the smaller partitions for a page file.One if I'm using xp,or the other when using windows 7.The other 750 gig drive is partitioned for games and storage.I also made another 2mb page file for memory dumps on my main drive.
I game on 1920x1080 resolution,and everything seems to run smooth.I get an average of 60fps on the most demanding games that I played so far,but I am wondering if maxing out my settings is hurting performance.I'm not sure.
I need tips to get the most performance based on my specs,
Thanks;)
Which specific drives do you have? I believe that you would be better suited by placing your XP partition on one 750GB drive, your Win7 partition on the other 750GB drive, and using your 320GB drive for page files.
I'm somewhat confused by your "question." If you want better performance at gaming, you're currently limited by your GTX 460. Simply put, it's not the best choice for single-card gaming at a 1920x1080 resolution. With your board, however, your limited by going with either one high-end card (like the HD 6950 or GTX 570) or two AMD/ATI cards (like the 6850) for CrossFire.
