Opteron X2 vs Athlon X2
jbladex
Alright from what I have read, it seems the Opteron X2 in comparison to the Athlon X2 is the same as the Athlon XP-Mobile vs Athlon XP. As in you get better overclocks, timings, and voltage. Is there any downfalls to using the Opteron as suppose to the Athlon? Arn't the Opterons supposed to be workstation CPUS? Was wondering if anyone can tell me the benefits of each to make it a little easier for me to choose which to go dual core with.
Opteron is same processor with 1mb l2 cache on all cpus. the x2's come with either 1mb or 512KB.
BigMacAttack, your wrong its 2 x 1MB which is 2 MB total, the same for both
So excluding the 4600+ and 4200+, is there any difference in performance. I noticed Opterons sell a lot lower, and I have heard that they can clock preaty high Basically why are Opterons considered server CPUs while Athlons are Desktop CPUs
slappy96 said:
No, actually he is right. ;)
How so.. look at any freaking store website
New Egg for Instance
Edit: Nvr mind, the lack of punctuation confused me.
However Question... why are the Opterons advertised as workstartion computers, while the others advertised as gaming/average user? Are they just the same exact thing, but different labels ?
Opterons have 3 HTT links instead of the regular one - unless you're using a multi-processor setup (not just dual core) you'll never use the extra links though. Being server parts, Optys are tested to a higher grade (since they've to be used in business environments it's more important they don't fail) and given more headroom when being speed-binned - this helps when overclocking. I have an Opty 170 here, rated at 2.0Ghz@1.35V, and running happily at 2.7Ghz@1.5V, 38°C under load with it's stock cooler. 35% overclock FTW!
If that was my machine, I would be hesitant to use 1.5v with the stock HSF. Yet you're only at 38c, which is amazingly low for such an OC and voltage with that cooler (I assume it's the heatpipe version). Nice going :) So did you just not run your furnace this winter? ;)
apparently the socket 939 opterons are identical to the X2's with the 1meg cache per core.
true for the 8xx series. 2xx has 2 ht links and 1xx has just one.
it is true that they go through more rigorous testing.. however, how can you explain the difference between these two charts. to me, it looks like the X2's are in the lead as far as mhz goes:
nice, but why don't i see your name in the post list in the database? ;)
http://www.eclipseoc.com/image/database/X2.png
http://www.eclipseoc.com/image/database/opteron.png
same reason i'm not there i guess, i haven't posted it for mine, but i'm at 2.75ghz on my opteron 170. my x2 3800+ could only hit 2.6...
Not looked at that database yet, and not quite finished finding the CPU max either - was happy at 2.4G, then 2.6G with my new board, then found a voltage bump gave 2.7G, which does seem to be the limit for now since it'll run 2 copies of Prime, 1 per core, for 8.5 hours at that speed, but fails on core 0 at 2.75G. Will run a longer Prime test once I've sorted my mem clocks - it's testing those back at home.
I'm new, initially signed up for the 3Dmark lists (which my details ARE on :-P). Not 100% on the exact details of my CPU either, though I do know it's a week 50 (0550) and was either UPMW or VPMW, can't remember which,thugh I do knwo it's whichever one isn't notorious for being rubbish overclockers - did a quick lookup and discovered it was right next to a rubbish batch, remember hoping it wasn't a similar sort of standard. I'm very pleased with it though. And yeah, it's the stock cooler with heatpipes - there's also a 120mm fan beside it which came with the case (Antec SLK3000B - TAC), but other than that no other cooling save the Enermax Liberty 620W PSU and stock coolers on the two X1900s. Now you mention it, that temp does seem a bit low - just did a brief check in Sandra since it's a recent install of x64 and a bit low on utils that'll give me temps. Will whack a copy of MBM on it and check temps with that, since Everest and SIW won't give me any readings. Unless anyone has any other suggestions otehr than just checking the BIOS after a quick reboot - seems a bit inaccurate?
Ah, it supports x64, that's good. Everest installs on x64 and mostly works OK, but won't give me any temp readings - or any data at all for my X1900s. Will try that once I get in - much obliged :)
