Opteron on Abit AV8?
C-Otto
Hi. I'd like to stick an Opteron 175 (2x 2.2GHz, 1MB cache) onto my Abit AV8. Is that possible?
Yes, my 170 works on it.
MB has some issues with my ram sometimes using this chip. Not always wanting to accept the ram but once it does don't take the ram out or you'll be trying to get it to accept it again. I don't know what the hell is up with it. No problem on my 3500, x2 on same mb same ram.
Okay, thanks. Any facts on 4x 1024MB with Dual Channel and DDR 400? I'd like to try that out at the same time :>
my bro is using a 170 clocked at 2.5ghz with no probs on this mobo.
If your memory controller can handle it and you know how to tweak WinXP to see all 4 GB, you should be fine.
