opteron and 7900 gt
I built this system on somewhat of a budget, I got the processor during the opteron craze with the certain builds that were very overclockable
I have one of the great opteron 146 build dates but never overclocked it. I have 2gbs of mix matched ram, pc3200 and pc4000, and a FSP 500w power supply, also with a 7900 GT, Its at that 1 year mark whether I decide lets upgrade the ram/mobo/cpu or just upgrade my current setup, now the only issue I have is, I can easily overclock this system to FX comparable speeds but I would need a decent kit of 2gb of ram... which run about 180-250 for dual channel ddr.... what are your opinions, should I drop 180-250 bucks on ram or just buy a new processor/mobo/ram and be up with ddr2 standards... If i was TO upgrade i would go core 2 duo/680i/ddr2
You don't need to get new RAM. Just lower the divider on what you have so it isn't running too far out of stock speeds.
I'd look at dropping in an X2 or dual core Opty. The rest of the system should be fine for another year or so.
the opty 146 have been known to hit 2.8-3.0ghz on stock air, the most ive ever gotten out of it is 2.4. I paid 215 for it as well. do you think dual core opty or x2 would make a big difference?
I had a 148 that flirted with 3ghz but never got it stable; also a DFI NF4 Ultra-D. This was on water though..
