Hello all,
It's time to replace my desktop. I'm currently running a P4 @3.0, 1.5GiB RAM, 6800GT 256MB.
I've been reading up on current hardware, and think I have settled on the E8400 for my new CPU, unless a better alternative is presented here, but I'm not sure what the best mobo would be for my build...
1) What will you be doing with this PC?
70% Gaming: WoW primarily, but the ability to run current and future FPS games at decent settings would be nice..
20% Web browsing and media use, some media transcoding as well..
10% Office/work related applications...
I would say Warcraft performance is the single most important thing to me here..
800-900$ (If the bang for the buck value is worth spending a little extra for better hardware then I could go up to 1000$) Shipping/Tax not included in my budget.
3) Where do you live?
Miami, FL USA (5 min from Tiger Direct outlet)
4) What exact parts do you need for that budget?
I will need: CPU, MOBO, RAM, CASE, PSU, HDD, GFX Card, basically everything BUT the optical drives.
5) If reusing any parts, what parts will you be reusing?
I have a SATA dvd-rw I would like to use - but should be all new hardware beyond that..
6) Will you be overclocking?
Yes.
7) What size monitor do you have or plan to have?
19" CRT at the moment, will be upgrading to 22"+ widescreen after building the new pc. Secondary monitor support would be a plus, as would hdmi(tho not a necessity)
3-4 weeks, would like to have the pc up and running by the end of January.
9) What features do you need in a motherboard? RAID and firewire are nice options to have, though I am not planning on running a RAID at the moment, I might change my mind down the line.. I can't think of any extra features I would need at the moment...
Thanks for your help guys!
Yes.
