Opinions on a Mobo
It's a great board. There are really no reasons not to go with it. In fact, it's one of my top three recommended P45 boards.
Wow. Well thats really reassuring coming from someone as active as you. Thank you very much!
mind looking over my build? :p
Everything looks good to me aside from the video card. I recommend you either go with this GTX260 for significantly better performance at a slightly increased cost after rebate, or go with a 4850 like this one to get slightly better performance for less cost. The 9800GTX does not offer very good value for $160.
Yes, that will fit, but you might be able to find a knockoff version of that cooler for less money.
Personally, I went with this one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150082
Seems to work pretty well for me.
I was looking at video cards also, and the one thing I don't like about the ATI cards is the fact that my monitor won't go into standby mode. It just displays "no signal" instead of powering down to standby like Nvidia ones do. Not sure what the deal was, but it was kind of irritating with my 4850, and seriously made me consider going with a 9800GTX+ instead.
thanks, i actually got the 9800gtx :p ill let you know how it goes
another question is
do you think its really worth it getting a cooler like that? wont the one that comes with the cpu do just fine? im not oc'ing or hardcore gaming
Not really, but considering the Xigmatek is the same price as the inferior Arctic Cooling heatsink, you might as well just get it anyway.
sorry i wasnt clear
i mean, is it worth getting one of these coolers or sticking with one that came with the cpu?
In that case, no. If you will be running at stock speeds, there is really no reason to purchase an aftermarket cooler.
The gigabyte boards are great especially the ultra durable ones. No reason not to recommend it to you.
Or something other than an Intel board for that matter.
Well, not necessarily. Sometimes there are features that other boards have but Intel boards lack. Intel's own-branded boards are generally extremely reliable though.
