Opinion: Thermaltake Mini Typhoon
picamiller
Thinking about getting one of these on my rebuild. AM2 install. Opinions? It will go on an ASUS Crosshair mobo.
Well, since I will be using the 5200+ which is a 89w processor vs. the 117w shown in the review for the 3000, and I will be OC'ing it to 218 on the bus, while the fact it says it is sufficent for a mild OC such as that, I should be ok.
The machining grooves on the face, should I polish that out?
My thermal paste is Artic Silver Ceramique.
I can also look into changing out the fan. (noise is not an issue since there are 7 80mm fans already in the case and a 140mm one in the power supply.
If there are machining grooves in the face, you can't just polish them out, you have to get some extra fine sandpaper and lap it down. Honestly, you'd probably be ok just having the Ceramique filling in the machining groves.
