aftereight
- Sep 24, 2008
Hey guys i just wanted some input on this spec such as compatibility and if any parts i've chosen are crap or unnecessary. It will mainly be used for high end gaming at a resolution of 2560x1600 (planning on a 3008wfp) for most things (im fine with 1900x1200 for stuff like crysis).
CPU: Intel Core 2 Duo E8400 Socket 775 (3.0GHz) 1333FSB 6MB L2 Cache Retail Boxed Processor £112.21
MOBO: MSI P35 Neo2-FR iP35 Socket 775 8 channel audio ATX Motherboard £61.87
OS: Microsoft Windows Vista Home Premium SP1* 64Bit 1Pk OEM £71.55
OPTIC DRIVE: LG GGC-H20L Lightscribe SATA 16xDVD±R +RWx8/-RW x6 Also READS - Blu-Ray & HD Disc's black £66.73
PSU:OCZ 780W ModXstream Modular Power Supply - Blue LED 12cm Fan 79.99
MEMORY:Corsair 4Gb (2x2GB) DDR2 1066MHz/PC2-8500 XMS2 Memory £71.06
GPU:2GB Sapphire HD4870X2, PCI-E 2.0, 3600MHz GDDR5, GPU 750MHz, 1600 Cores, 2x DL DVI/ HDTV £364.12
HDD: Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII *32MB Cache* - OEM £81.89
CASE:NZXT Tempest gaming case £68.95
Extras:
Thermalright Ultra-120 eXtreme 120mm Heat Sink Fan for AMD/Intel CPU £34.89
Logitech G51 5.1 Speakers 155w RMS £85.65
TOTAL: £1099.33
MAX BUDGET: £1400
This will all be air cooled on the 6 case fans. Will all this be enough?
Extras:
TOTAL: £1099.33
MAX BUDGET: £1400
