Opinion needed.
brysig228
my fairly new system is e6600, asus P5NSLI, evga 7600gt, 250g sata/80g ide HDD, 2g or ram( 1g ocz and 1g hynix), plextor dvdrw. now my dilema is should i replace the motherboard or get another gpu? oc is limited with the mb and my highest was 2.92g. if i was you would you replace the board and what will you replace it with? my budget is $100 more or less on the board. OR would you get another gpu and make it in sli mode? i'm itching to spend some $$ but not a whole lot :D
thanks for your input.
For games, your system is very GPU limited, so I'd get another GPU.
For just general system preformance, a new motherboard.
Games: New GPU
Something Else: Motherboard
Dunno why your mobo is limiting your overclock. Its most likely ur mixed ram. I have the same board and i got my e6300 to 3.24 with ease. could go higher but no need.
i wouuld get some better memory or set it as unlinked in bios. do u game? 7600gt is ok for moderate gaming is smaller resolutions.
your mobo is the P5N-E and i have the P5N-SLI that is why it's limited with my oc. the only game i play is CS:S and my 7600gt runs just fine with it. i was thinking of just replacing the mobo to gigabyte GA-965P-S3. anyo opinion is welcome and appreciated.
the s3 is good, as is the tforce 965p from biostar. msi has an affordable 650i sli board as well.
I have that particular pair of RAM. It reaches a max overclock of about 430MHz to 450MHz. It's pretty decent and cheap pair of 2GB RAM.
