I have a similar policy in place, but for a diferent problem. It's a swear jar. When ever it reaches twelve dollars (25 cents per offense), someone takes it and stops at Krispy Kremes the next day for rolls. I usually eat free rolls every three days.Josh_B said:This income can be placed into a pool which would be used for user education regarding such things as social engineering, or spyware-proofing.
However, for reasons listed, viri are less of a threat to my Linux only box then they are to my family's windows boxes. It's not that Linux is more secure against viruses, but there are simply less, so the result of that is that I am safer.BillLeeLee said:I'll tack on one that focuses more into your "Operating System A is more secure than Operating System B"
Windows is filled with insecurity holes and is prone to virii, more than Linux/BSD/Mac OS X
Yes, it may seem like that because every month, or possibly every week, we get reports in saying "New major critical security flaws found in Windows software," or "New virus/worm on the rampage on Windows machines."
Well, part of the equation is that MS owns something like 90% of the market with its operating system, and if people want to do damage with a virus or exploit, it's best for them to target the product with the biggest market share.
Linux/*BSD/Mac OS X aren't exactly impervious to security threats - you have to keep them updated and do many of the same things you'd be doing on a Windows box, like run a firewall and antivirus.
Linux has a flaw in the 2.6 kernel that would allow a certain piece of C++ code to crash the computer. It was fixed in the 2.6.7 kernel and I think patches might have been released for the other kernels (not sure).
I'm not really sure on the *BSD front myself, but as a whole, if you can't take care of your computer and protect it correctly, then it doesn't really matter what you're running, because you're still open to root kitting, trojans, etc.
Thanks to XOR != OR for expounding on the virtues of the firewall and AV for Linux, and those who shared Linux/Windows security knowledge
GeForceX said:Wow, I may seem off-topic but for a computer that only has so much memory should at least disable services to save memory. If you're going to have a PC that doesn't do any printing nor file transferring nor any intensive work nor office work then it makes sense to disable those not needed and get a more responsive system so you can enjoy chatting on AIM/MSN/whatnot and search the internet on the fly. I'm not sure how much megabytes you actually preserve when you disable all but the necessary services but I'm sure it is 1 to 4 MB for each service. For me, that is quite a bit. You *BET* you will see improved performance/smoothness if you disable your services while playing Doom 3 rather than letting it soak up the memory that Doom 3 would very much desire/need. For those that argue, I would like to see you set up a 300 MHz 64 MB RAM computer on Windows XP Pro. It could probably barely even run with the services enabled. Probably MAY run better without the services. I have yet to comprehend how disabling services does NIL performance for you. No, I am not necessarily speaking of frames per second or anything like that. But surely a responsive system with perhaps less file paging (although not that noticeable-- but enough for older PC's).
-J.
He's wrong about the list of services he's calling "security holes" on his list, as well as the ones he's claiming don't matter. He's once again going on vague information instead of tracking what each of the services actually do and are used for.GeForceX said:Can you verify if it makes any sense? He says it's more propaganda which should be agreed by you.
Because people will blame any problems on the things they don't understand, since it's easier than actually learning to understand them and figuring out what is actually happening or going wrong.GeForceX said:How come back then we hear of many cases of slowdowns caused by Windows XP services then?
GreNME said:There is no one website that will answer your questions. It's too broad and too vague a question for a single answer, which is why there are none. I'm working on an article to explain what the Windows-default services are, what they do, and why disabling them is not a good idea. Things like messenger and are usually okay to set to manual, but going much further than those is a recipe for disaster.
And yes, if you're installing SP2, having disabled services is likely to screw things up. I wish there were a decent way to get a tally of how many of these hosed systems had services disabled versus didn't as an example. I can guarantee you that if you have either QuackViper's or that fluffygerbil's recommendations for disabling services, you will very likely experience problems either during or after installing SP2.
Oboy, here we go...O[H]-Zone said:I've got lots of services disabled, and had no problems with installing SP2.
Apparently, you weren't aware that SP2 disables that for you.O[H]-Zone said:Windows Messenger is a service that's on by default, and it's baloney. Kill it.
Since that's not how it works, you're showing your ignorance about the service.O[H]-Zone said:Also, the Corporate Pro version installs with the Remote Registry Modification enabled...I can't speak for you, but I don't want anybody remotely modifying my registry.
Concurrent logons are not possible in XP. Once again, you are ignorant to the purpose of the service.O[H]-Zone said:Secondary logon service...I don't want anybody else logging on to my machine...disabled.
For ridiculous reasons, I'm sure...O[H]-Zone said:Error reporting...disabled.
Even though when there are no wireless devices, this isn't taking up any cycles or RAM (and negligible ones when running). So you accomplished nothing by disabling it. Congratulations.O[H]-Zone said:Wireless Zero Configuration...disabled.
When choosing classic accomplishes the same thing without risking a conflict. Congratulations again.O[H]-Zone said:Themes...disabled.
Hope you don't bother syncing different portable media to that one machine. Expect problems if you do. PCMCIA conflicts can originate for people who disable this on laptops.O[H]-Zone said:Portable Media Serial Number service...disabled.
For incredibly stupid reasonsdon't believe the BS that is spread about QOS.O[H]-Zone said:QOS RSVP...disabled.
Then it doesn't run or take up resources anyway. The only time it actually runs is when you plug something in. Good job accomplishing nothing there, and screwing yourself if you buy a pen drive for transferring files later.O[H]-Zone said:Removable storage...aint got none...disabled.
Wow... you are really just shooting blind here.O[H]-Zone said:Routing and Remote acces...this machine doesn't do any routing, and I don't want anyone remotely accessing it...disabled.
As with many others, if it's empty, no resources are used. However, you just screwed programs like Norton A/V, many backup programs, some 3rd party defrag programs, and many others. Great job removing capability for absolutely no reason.O[H]-Zone said:Task scheduler...disabled.
No they didn't, and the ones that did, counted together, do not take up more than 5-10 MB of memory and a fraction of a percent of CPU cycles in almost every case.O[H]-Zone said:None of these are needed...all use system resources.
O[H]-Zone said:I've got lots of services disabled, and had no problems with installing SP2. Windows Messenger is a service that's on by default, and it's baloney. Kill it. Also, the Corporate Pro version installs with the Remote Registry Modification enabled...I can't speak for you, but I don't want anybody remotely modifying my registry. Secondary logon service...I don't want anybody else logging on to my machine...disabled. Error reporting...disabled. Wireless Zero Configuration...disabled. Themes...disabled. Portable Media Serial Number service...disabled. QOS RSVP...disabled. Removable storage...aint got none...disabled. Routing and Remote acces...this machine doesn't do any routing, and I don't want anyone remotely accessing it...disabled. Task scheduler...disabled. None of these are needed...all use system resources.
And on top of this, one can still gain access to your registry with this turned off. Just not through the administrative console.Remote Registry - First off it require administrative level permissions to access, so if you've got a good password on your system then your safe. This service allows admins to remotely modify the registry.
O[H]-Zone said:Remote Registry - First off it require administrative level permissions to access, so if you've got a good password on your system then your safe. This service allows admins to remotely modify the registry - and if the service is turned off, there is less opportunity to do so. End of story.
O[H]-Zone said:Secondary Logon - This service allows you to start a program using alternate credentials. For example if you were running under a regular user account and needed to run a program as admin you could do so without having to logoff the system. Secondary logon does not have anything to do with someone else logging into your system. - And since I only ever use my one account, it is nothing but a security hole. End of story..
O[H]-Zone said:Since that's not how it works, you're showing your ignorance about the service. - wrong. That is how it works. Please stop calling me names.
O[H]-Zone said:Every single thing I've ever seen you say here has been utterly, completely, and totally wrong. And all you do is flame and argue. It doesn't make you right, and I'm PM'ing a Mod about the flamage...I'm sick of it. If we can flame here, then I have some things to say to you...it's my understanding that we can't. I've had enough from you; if you can't make your point without calling me names, then I have no use for you.
For the love of God, people...don't listen to this person.
It's just a re-hash and paraphrasing of the QuackViper stuff (which was just cut-n-pasted from other uncredited sources). In other words, it's third-generation inaccuracies.Moto Guzzi said:
Of course, he's only speculating about the performance, because there is no measurable gain.The Elder Geek said:Frankly, I don't recommend you change any of the services from the default installation of XP. Yes, you may pick up a tiny performance gain by fiddling with the settings, but it won't be anything substantial. It's just my opinion, but if you are in a situation where these gains are necessary to achieve an increased level of system performance, it would be wiser to upgrade the physical system to one that is adequate to benefit from the XP operating system.
Once again, a combination of misinformation, conjecture, and paranoia. No, someone couldn't elevate privilages on your machine if you're the only account, because there are no other accounts that can be used. The guest account is disabled by default. That is, unless you enabled it, in which case you just threw your previously assumed 'security' out the window, since a null session, anonymous, or 'guest' account can run an attack on your password anyway. As someone who has been learning techniques for cracking into NT/2k/XP machines for a while now, I can assure you that you get no safety with your admin account by turning that service off.If someone SHOULD gain access to my box through some other account, they could then begin an attack on my admin password. Thank you, no.
O[H]-Zone said:Remote Registry:
Direct quote - "Enables remote users to modify registry settings on this computer. If this service is stopped, the registry can be modified only by users on this computer."
Hmmm...again, I don't want "remote users" modifying my registry, thank you...
Secondary Logon:
Direct quote - "I find this feature very useful but it does compromise security so be aware of what it can allow." Since I run as admin, I don't need "run as". If someone SHOULD gain access to my box through some other account, they could then begin an attack on my admin password. Thank you, no.
O[H]-Zone said:Secondary Logon:
Yogi said:You might want to mention that Linux can be used with lighter GUIs like XFCE and the *box window managers. They can be good alternatives for old machine that you want a GUI for.
I'm not disputing that right. Anyone who owns their system has a right to do what they please. My contention is with trying to pass it off as a performance/security/whatever tweak.BobSutan said:Gren, yes disabling the services in question provides very negligable gains, but if O[H]-Zone wants to disable them then that's his right.
The thing isand it's something that I've already pointed out and is being ignoredis that when the service isn't being directly accessed/used, it isn't running. Being started in the list in services.msc does not mean it's going to be there when you run a task list check. In fact, more often than not, you'll find that at least half the things listed as "started" in services.msc are not actually running, they are in a "ready" state to be run (or are waiting to be initialized by an authenticated user with privs).BobSutan said:He's also got a point in that if its not needed, then why let it run? Defacto security mantra tells you to disable anything not absolutely neccessary for a particular computing environment, which is essentially what it appears he's shooting for.
No argument here. When I run a live CD of Linux on my old 233 lappy with fluxbox, it kicks ass. However, with those lighter GUIs, you also lose a lot of the integrated features of the likes of GNOME and KDE. As much as I like fluxbox (on Linux), it's no KDE. It makes a better graphical toolbox than it does graphical environment.kleptophobiac said:I'll vouch for that. I have a 486 DX4/75 with 24MB of RAM that runs fluxbox on X 3.3.6 on slackware 9.1 - and it flies. Pair that with a lightweight browser like Dillo, and your old hardware really can be spectacularly fast for what it is.
You can turn off fast user switching and get the same result with less potential for problems later (if you ever change your mind and forget about the disabled service).Themes really isnt necessary if you use classic, and if you use the classic logon (like I do) you still see that horrible blue bubbly stuff when you login.. If you disble themes you get a nice classic looking logon... its easy and if i never touch a theme, why should it even be on the list of things to run?
Just curious: what all can you accomplish with it? Since you mentioned a recent kernel (slack 9.1) and all, you must have a crapload of stuff not installed and intentionally removed to be using a grand total of 14 MB. I take it the machine is a web surfer?kleptophobiac said:50-70MB of RAM? wow! That would choke my 486 laptop. It's running 24MB of physical RAM, and when I load dillo it still has 10MB free.
