Shadow2531
- Jun 13, 2003
Opera are doing their best, but I believe the solution lies here.
Nazo said:ROFL! Just for fun:
http://validator.w3.org/check?uri=http%3A%2F%2Fgmail.google.com%2F&charset=%28detect+automatically%29&doctype=Inline&ss=1&outline=1&sp=1&No200=1&verbose=1
Bear in mind, this is just the login page alone... You know, those few lines of text and a small form... How the heck google managed to put so much code behind such a simple thing is beyond me...
No wonder they have so many problems with browser support!!!
EDIT: Just figured out what the problem was all along. I had created a UA.INI file because I didn't get one when I was trying to use this method for the first time (when B2 first came out.) I deleted my UA.INI and used the check for new versions to generate a new one. I think I figured out the problem. At the top, in the commented out part, it tells me the file is stored in UTF-8 format. I set my editor creates files as standard dos/windows text instead of UTF-8 because I need maximum compatibility. I bet the problem was that all along. Anyway, problem solved.
Tangent said:Opera8 b3 is giving me trouble on gmail as well. It appears to load up normally, but the screen stays blank. Once I hit F12 and change the Identify As, just click on the one that it's currently using, or even just click on another browsing tab and then back on the gmail tab the screen pops up...![]()
Nazo said:Maybe try adjusting the redraw setting in the options? I have mine set to "redraw instantly."
Quick comments about the reasoning behind the new dialog:
We wanted to make the most important/basic settings more easily available while keeping most of the old settings.
For instance, Personal Information used to be burried in a long list, now we try to invite users to fill in their data since it adds valuable functionality to the daily use of Opera.
One can argue that you hardly ever change the Wand settings, so they shouldn't be as prominent, but we feel that too few people actually took advantage of it (and got a worse experience) and wanted to change that. "Special" fields are probably coming back, btw.
Same thing with the choice to use tabs or windows, it should be on the opening page of Preferences so we don't have to bother the user with difficult questions on first start-up.
The language choice is not entirely finished, but the idea is again to lead the user to make a choice when it matters to them. Web language was a fairly advanced choice previously for a very basic functionality.
"Advanced" is meant for settings you shouldn't need to touch the first few days you try the product, but not necessarily things you never change - as we all know by now
