Does anyone here know why Open Indiana VMs cannot boot with more than 2 virtual cpus? Is this a bug that will be fixed soon, or some inherent limitation?
ESXi 4.1u1
Supermicro X8DT3, 2x XEON L5518, 4x8GB regECC
5x WD VelociRaptor 600GB connected to the on-board LSI 1068E,
passed through to the storage OS (OpenIndiana b_148, 6 GB RAM) and then used as a striped mirror (RAID10) + spare
OI is using the "vmxnet3" adapter to connect to the internal virtual network that connects the OI SAN with ESXi.
The "VMstorage" pool is shared to ESXi via NSF.
Yes, you have discovered suck win7 feature. If it is ultimate, doesn't it have NFS client available? I think so, but it isn't installed by default. Failing that, create an iSCSI target?
mount [o Options] \\ComputerName\ShareName {DeviceName | *}
Should not need smb, no. What did you do on OI to enable nfs for that share?
More specifically, what do you get from the command:
sharemgr show -vp
default nfs=()
smb smb=()
* /var/smb/cvol **
c$=/var/smb/cvol smb=(abe=*false* guestok=*false*) *Default Share*
zfs
zfs/Hitachi_9TB_array/Storage smb=()
Storage=/Hitachi_9TB_arrayStorage
User and Group-management. Unix-System-user ex. root,admin,avahi,mysql,nfs,napp-it are not shown
chmod 777 /Hitachi_9TB_array/Storage
I tried it with the e1000 NIC, but no luck:I would prefer you ran the e1000 NIC in the OI VM - I and others have seen glitchy behavior from the vmxnet3 NIC.
Gea
anything to look out for when installing SSD as os drive?
Thanks
hi gea
anyway i plugged in an intel g2 80gb which i got it cheap.... but i forgot to export the settings from the previous os drive
now after importing the 2 sets of raid1....and joined my AD
I can't access to the smb shares via my domain administrator account
any idea?
