Tonight i'm changing from solaris 11 to OI .... worry!!
Why not go to OmniOS?
Hello!
I installed OmniOS today on my new SAN:
- AMD FM2+ motherboard
- AMD A4-xxxx CPU
- 8GB memory
- Intel PRO/1000 CT nic
I get a good write speed(around 92MB/s) over SMB, but read speeds are low(only around 52MB/s).
NFS goes full speed.
I also tried FreeNAS, and I get 100(read)/90(write) over SMB protocol.
Is that a know problem?
Is it solvable? How?
Matej
Hi guys!
Is there any way to release control of a file that's in use?
I have a smb share (provisioned trough Napp-It and using OpenIndiana) with guest access set to ON.
Every now and then I can't get access to certain files because someone else is using them.
It gets annoying since all computers are OFF, and the only way to "free" these files is to preform a server restart.
In Linux I believe there is a smbstatus and smbcontrol command so you can kill the PID or close all clients connected to a share.
In Server2K8 you can kick a user through Task Manager or use Share and Storage Management to see who's using a particular file and close connections to it.
Can someone point me in the right direction? Restarting a server is.. well.. not optimal..
Hey,
just wanted to let you know I've just installed Napp-It on OI-hipster-gui-20131210 (wanted a Gui and current stable does not support i210), no issues.
Upon installing Ampo I had to set up the path to mysql though; you might want to include that in ampo2.sh
Edit:
Oh well, to soon
Upon importing an existing Pool:
cannot share <poolname>: smb add share failed
package file subroutine line
main admin.pl main::my_action 518
main /06_pools/03_import/action.pl main::my_do 17
main /06_pools/03_import/action.pl main::error 131
Creating a new pool works fine (incl sharing)
What is an URE?
`joomla/plugins/editors/tinymce/jscripts/tiny_mce/plugins/safari/editor_plugin_src.js' -> `/omnios/joomla/plugins/editors/tinymce/jscripts/tiny_mce/plugins/safari/editor_plugin_src.js'
cp: cannot create regular file `/omnios/joomla/plugins/editors/tinymce/jscripts/tiny_mce/plugins/safari/editor_plugin_src.js': Operation not permitted
`joomla/plugins/editors/tinymce/jscripts/tiny_mce/plugins/safari/editor_plugin.js' -> `/omnios/joomla/plugins/editors/tinymce/jscripts/tiny_mce/plugins/safari/editor_plugin.js'
cp: cannot create regular file `/omnios/joomla/plugins/editors/tinymce/jscripts/tiny_mce/plugins/safari/editor_plugin.js': Operation not permitted
rsync: mkstemp "/omnios/joomla/administrator/components/com_templates/.index.html.gYKDOw" failed: Operation not permitted (1)
rsync: mkstemp "/omnios/joomla/administrator/components/com_templates/.templates.xml.exWYLJ" failed: Operation not permitted (1)
rsync: mkstemp "/omnios/joomla/administrator/components/com_templates/.toolbar.templates.html.php.0bG6WW" failed: Operation not permitted (1)
rsync: mkstemp "/omnios/joomla/administrator/components/com_templates/.toolbar.templates.php.5wyZ89" failed: Operation not permitted (1)
rsync: mkstemp "/omnios/joomla/administrator/components/com_templates/helpers/.index.html.qSFt8m" failed: Operation not permitted (1)
I have no idea what FreeNAS NFS client is so slow...
I will do some testing with iozone tomorrow as well, but probably only over NFS.
Matej
You should remind people if they go that route and create a new array, the new array will have features unsupported by most other NAS OS builds out there and therefore be impossible to import should they switch OS to something else.
Indeed OmniOS is quite the closest OS to Illumos, the source of any free ZFS. But with OpenZFS the delay between Illumos based ones like OmniOS/OI/SmartOS and the others like BSD and ZOL is quite short.
A ZFS pool from current OmniOS should be importable in current FreeBSD or ZOL as well as they use the same set of features.
Hello!!
I'm trying to setup NFS and SMB shares with ACL support and I got into troubles...
As of about two weeks ago I know my pool was not importable on OI or FreeNAS, two of the more known distributions of NAS software
root@biglittle:/pool0# /usr/bin/ls -Vd share/
drwxrwxrwx+ 17 1044 100 18 Jan 31 15:50 share/
user:root:rwxpdDaARWcCos:fd-----:allow
user:levak:rwxpdDaARWcCos:fd-----:allow
owner@:rwxp--aARWcCos:-------:allow
group@:rwxp--a-R-c--s:-------:allow
everyone@:rwxp--a-R-c--s:-------:allow
/usr/bin/chmod A- Folder1
/usr/bin/chmod A0=user:root:rwxpdDaARWcCos:fd-----:allow Folder1
/usr/bin/chmod A1=user:levak:rwxpdDaARWcCos:fd-----:allow Folder1
/usr/bin/chmod A2=owner@:rwxp--aARWcCos:-------:allow Folder1
/usr/bin/chmod A3+group@:rwxp--a-R-c--s:-------:allow Folder1
/usr/bin/chmod A4+everyone@:rwxp--a-R-c--s:-------:allow Folder1
/usr/bin/ls -Vd Folder1
root@biglittle:/pool0/share# /usr/bin/ls -Vd Folder1/
drwxrwxrwx+228 1044 1038 352 Jan 31 14:47 Folder1/
I just wanted a GUI
I only use the GUI for the updates of packages the rest I do with the Nappit GUI but I saw this mentioned on the OI IRC channel:I do not expect that OI will cancel the GUI.
But you can also add a GUI to OmniOS as well,
see http://pkgsrc-us-east.joyent.com/changes.html#major-changes-in-pkgsrc2013q4
And there may be other options with GUI like http://sonicle.com/index.jsp?pagename=xstreamos&parent=products
[10:32.48] <mickey_> found this discussion: JDS menus and launcher gone is there any solution right now?
[10:34.29] * alex1 ([email protected]) has joined channel #openindiana
[10:36.45] <tsoome_> from which version did you upgrade?
[10:37.27] <mickey_> i did a upgrade from 151a8 to a9
[10:38.21] <mickey_> found this here http://www.archivum.info/[email protected]/2013-09/00110/Re-%28OpenIndiana-discuss%29-oi-151a8-JDS-menus-and-launcher-gone.html
[10:38.34] <mickey_> but using admin role seems not to be in ideal solution
[10:39.39] <tsoome_> I have no a9 myself, but from people are talking about is sometimes it can happen that some files or packages are not getting updated properly
[10:40.12] <tsoome_> so, what you wanna check is to get installed package list and verify they all have updated version string
[10:40.43] <tsoome_> also, it may help to check .xsession-errors and /var/log/Xorg.log files
[10:41.44] <tsoome_> also, possibly, clean up the gnome related .files and directories and get them recreated
[10:42.04] <tsoome_> thats for your home
[10:43.22] <mickey_> thx! will try to find my way through your cues
[10:44.02] <tsoome_> I only have hipster myself and haven't been hit by this issue
[10:44.18] <mickey_> how stable is hipster anyway?
[10:44.51] <tsoome_> they are all fairly stable tbh.
[10:45.22] <tsoome_> sometimes you can see problems like the issue you got with gnome
[10:46.52] <tsoome_> what I am doing is, update often and keep a bit of history around for beadm, so you can switch back if needed
[10:47.28] <mickey_> i see. i just wanna setup a stable systeme once (for nas purpose)... i devided for openindiana for stability reasons and now gnome doesnt work and napp-it either, good start hugh?! :D
[10:47.51] <tsoome_> well, gnome is not important at all for nas;)
[10:48.08] <mickey_> true, but nice to have! :)
[10:48.59] <tsoome_> the main focus on all opensolaris - now illumos based distributions is the main system. desktop is nice to have but the manpower is somewhat limited
[10:49.39] <tsoome_> more contributions/help/input is always welcome to get things more smooth
[10:53.35] <mickey_> yeah, hope that this project continue
[10:54.37] <tsoome_> it was in an hibernation before hipster was started, now there is a lot more life in it.
[10:56.14] <tsoome_> but yes, the main focus is still about server side, smartos, omnios, nexenta etc are keeping the wheels running;)
[10:58.00] <mickey_> :)
[02:14.44] <Socra> Q: If I do an upgrade packages on my 151a7 will it upgrade to a8 or a9 by default..?
[02:15.13] <Woodstock> i would expect it to go straight to a9
[02:23.14] <Socra> yeah thought it might..
[02:24.32] <Socra> I using it with NappIT and every now and then I upgrade OI then NappIT but I'm not eager If I read the problems mentioned above
[02:29.23] <tsoome_> you can set version where to update
[02:31.39] <Socra> tsoome_ where can I do that..?
[02:33.21] <tsoome_> pkg update entire@version. you can get version for example with browser while browsing the repository
[02:33.33] <tsoome_> or with pkg search
[02:41.22] <Socra> so only through cmdline or also possible through the gui of the pkg manager..?
[02:44.23] * Socra feels to noobish in OI world
[02:53.41] <tsoome_> no idea about gui
[02:53.57] <tsoome_> gui is almost dead anyhow
[02:54.20] <tsoome_> and probably will be gone unless someone will start to work with it.... :D
[02:56.39] <Socra> lol
[03:01.01] <tsoome_> its already gone from hipster btw.
@Gea,
Congratz on the new appliances, excellent work again!
The current production version is:
Version 13b, Jan 11 2014:
OmniOS 1008 stable, napp-it 0.9d2/ 0.9e1 with vmware tools 5.5 and vmxnet3 + e1000)
What is your planning on releasing updates for the appliance..? are you going to create a new appliance once a new update/version of OmniOS comes out or will there be just the version 13b VM and keep Nappit + OmniOS upgrading from there on?
Maybe its easier to
- smb login as root and set all ACL from Windows
This is ok unless you do not need deny rules as they work different on Windows and Solaris.
And set zfs properties aclmode and aclinherit of the filesystem to pass-through
more infos
http://wiki.illumos.org/display/illumos/CIFS+Service+Troubleshooting
No mapping between account names and security IDs was done.
I tried that and it's not working. Same error... No error on the newly created folders and files though...
Also, if I try to change permissions on root folder or any other subfolder, I get error:
Code:No mapping between account names and security IDs was done.
lp, Matej
root@element:/share# ls -l
total 60
dr-xr-xr-x+ 2 user1 root 30 Jan 3 10:46 Folder1
root@nas:/pool0/share# ls -l
total 60
drwxr-xr-x+ 2 1010 root 30 Jan 3 10:46 Folder1
I'm not sure where I should post this to be honest but I've loaded up a fresh copy of OI with GUI and then installed Napp-it which is all ok and works as expected, if i open the task manager to view ram / cpu and network usage and then run the internal benchmarks through the napp-it interface, napp-it shoes that i'm using most of my ram (I can't remember the figure off the top of my head but It was around 6Gb out of 8Gb) but the task manager in OI shows that I'm only using 360-ish MB at the same time.
I'm a little confused as to why Napp-it shows high memory usage but the OS shows little to none at all?
