I've found FreeBSD to be a genuine PITA to get anything running on ZFS.
Nevermind the day-long installs, the mysteries of package ports, the lack of virtualization capabilities, the onerous Zones implementation, and all the fun of dealing with semi-supported hardware - BSD in general seems to be best in purpose-built distros doing a speciality. Like pfSense or FreeNAS.
Unless you want to devote a few months or years, BSD's biggest plus is its license and its specialized distros.
And no, no BSD yet has as good an implementation of ZFS 128 as OI.
Alasdir is right: OI may suck but it doesn't suck as bad as the free alternatives.
not speculations on zfsonlinux, this is on going work. you can see zfsonlinux milestone.
it works without significant problems, try it by yourself![]()
I do not think Oracle would bring ZFS to linux, mostly on porting and change opensource license. Oracle can make money on that.
Oracle buys Redhat? I do not see in near future
could you reveal your speculations that can be shared to us? please..
Frequent crashes: F17/18/19, CentOS 6.3 & Ubuntu 12.04; multiple reasons.
The CDDL was created to be GPL-incompatible, in part over ZFS, and is worth billion$. Oracle would just about have to go into receivership, or ZFS would have to be obsoleted by something else (nonprofitable) before they relaxed the CDDL for ZFS on Linux with nothing in return. Nonstarter. Too much fkn $$.
'Competitors' Oracle and RedHat have become quite cozy of late. A lot more going on than just Oracle's RHEL tracker/clone and UEK and RHEV. There's 'positioning'.
Watch Oracle snap up the leading enterprise Linux provider on the planet, or become RHEL's "ZFS partner" as soon as their numbers show significant competitive threats in the enterprise Linux ZFS segment. ?
Then again, RHT's board could well have immunized their company from just this sort of thing, which is why it's playing out the way it has...?
[/(speculations)]
You can be pretty certain both ORCL and RHT have kicked around the idea in one form or another.
1) We are talking about ZFS, not virtualization. I've never had a reason to try freebsd as a vm or as a host.
2) Never had a day-long install (what hardware are you trying this on?)
3) No use for zones
4) I have no issues with hardware, practically EVER and I've used OpenBSD since the 2.x days & FreeBSD since the 4.x days.
5) pfsense is OK, but it helps if you've worked with openbsd pf (I have for MANY years before tackilng pfsense). I've been using OpenBSD as a firewall distro sine the 2.x releases.
6) FreeNAS (was/is?) buggy & limited compared to freebsd.
7) FreeBSD is documented VERY well (see freebsd handbook). Ports & packages are super easy to install.
centos 6.3 with zfs, pretty solid, there are some issue with it. tried on ubuntu and had problem where I stop to use ubunut for awhile.
I am lucky enough ?....
we will see your speculation.
Redhat is cozy? can you explain..
partnering are not always buying at the end.
you have to distinguish "company" and "developing" on GPL spirit
Redhat and other companies provide their effort in kernel and fixes too.
ZFS would not absolete in near future (4-5 years in my expectation) unless we have a stable breakthrough filesystem.
RHEL-ZFS(oracle)? heheh I do not see in a long run..
you can read RHEL scalable filesystem -> http://www.redhat.com/products/enterprise-linux-add-ons/file-systems/
Redhat has their own business model and let them drive...
