Open side panel, fan blowing inside computer 24/7...feasible?
tjmaxwell
First off, I asked this in the general hardware forum already and people suggested I ask here. Sorry for the duplicate post.
I have an SLI rig that's running really hot (FX-55: 70-75C under load). It's also a fairly loud rig as you might expect with two GeForce 6800GTs. Anyway, my desk is currently up against the back wall in my basement. On the other side of the wall is our laundry/storage room. Rather than spend a ton of money on expensive heatsinks/fans or a watercooling setup, I was thinking of putting the machine in the storage room, leaving the side panel off, and having a table fan blow on it 24/7. I tried putting a fan on the floor blowing on my computer for about 10 minutes last night, and all the temps dropped like 15C almost immediately. Not only would this cool the machine much better, but it would also eliminate the fan noise. This would also be very easy for me to set up, but I'd probably end up leaving the machine on all the time. The only worrisome thing I can think of is lint from the dryer, but the room is about 20-feet wide, and the dryer will be at the opposite end of the room. Also, the fan blowing on the PC will be pointing towards the dryer, so there's little chance of the lint being sucked over from the fan.
So, the obvious question is whether or not there are any other implications with this setup. As long as I was careful to blow out dust on a regular basis, are there any other problems with a setup like this?
not at all, people have used box fans a lot of times to cool there systen
you could construct some sorta grill on the outside of the case if you're real worried about the lint/dust issue :p
Those temps sound inexplicably high, I'd first take a look at what's causing them... Even with two Ultras it shouldn't be that high unless a) it's OC'd to the hilt b) the Ultras have the crappiest stock cooling solution ever.
