Open Box P5Q Pro?
Open box means 2 things.
1. There may be parts or manuals missing.
2. Someone bought the product before and returned it for some reason.
You have no way of knowing why it was returned, but the fact is that it was returned and usually returned missing a manual or accessories so the retailer can't just box it up again and pretend it's new.
Open box means it might be the one I sent back, and believe me when I tell you that you do not want that one.
Is the P5Q Pro worth getting new?
I don't know another Mobo to go for and a few people have recommended that one.
I tell you what- it's the board I'm going to get. I keep watching the price go down and then back up. It's not worth the torture to save 20 bucks- just buy it lol.
I've done quite a lot of research- and the board seems solid, and fits my needs.
So, if it fits your needs, I don't see any reason not to go with it.
I believe the Deluxe is a more solid choice, the Pro seemed kind of low end to me compared to higher end Asus boards.
I considered the deluxe but, not for $200.
The P5Q is only $140 atm, and from what everyone says it seems to be a solid board that makes OCing a breeze.
I've bought a lot of "open box" products from newegg, most of them look brand new and work fine. I've rarely ever encountered a broken item (I think 2 over the course of nearly 8 years now shopping at newegg) with their "open box" stuff. It's definitely worth trying, 99% of the time it's perfectly functional, and the other 1% of the time you can just return it within the 15 day period as defective for a full refund if not. The "open box" can also mean that it's a factory refurb.
