- Feb 1, 2005
So who's ordering today? I think I'm going to wait a few weeks for a couple of reviews before I jump
Me too.
I would like too but I just got my 5T. I would jump on the 8GB 128GB model and probably the white colorMe too.
Bought it... holding on to my OP5 just in case I'm unhappy, really only the glass back and fingerprint reader on the back bother me... glass will be covered / protected with a case and fingerprint on the back is kind of the new standard so I guess i just have to adjust...
Considering how large it is, fingerprint reader on the front would be a pain to use. Personally I think back is perfect. Only downside is when the phone is on the table, you have to pick it up first. My Honor 8 has fingerprint gestures that make it even more useful.Bought it... holding on to my OP5 just in case I'm unhappy, really only the glass back and fingerprint reader on the back bother me... glass will be covered / protected with a case and fingerprint on the back is kind of the new standard so I guess i just have to adjust...
On screen would be the best. Though, if it's on the back it can be a button too. On Honor 8 for example it's a button and a fingerprint reader. Long press takes screenhot, one press launches camera and swipe down brings the notification area down (swiping up does the opposite). Swiping left/right in the gallery lets you switch to next/previous image. With on screen reader all that functionality would be gone. At least the location would be better than front bottom.I'm hoping for on screen fingerprint scanners on the next round of phones.
Got mine today, I'm pretty happy, a few kinda buddy things that annoy me that they fixed on the 5 that are "back" / shouldn't exist on this phone but I assume will be fixed soon. It came with a case in the box that I didn't know about so I'm irrationally annoyed that I bought one as well. It's super fast, the face unlock makes me giddy, gestures, 19:9 and the notch are everything I ever wantedOh and side by side I get 40 extra mbps on my wireless next work! Color me impressed
What are these annoying things? Mine is arriving on Tuesday.
I'm slightly concerned about the size of the fingerprint scanner and how well it reads
in stock form due to the notch you can't have battery %. Also I would just switch to the gesture navigation. Gets rid of the dumb navigation bar and with the better to screen body ratio you will get that extra screen space back. It takes a few days to get used to but it's second nature after that. Plus for me I was hitting the home button to many times when using the stock keyboard.1. The battery icon in the top right doesn't (won't) display a percentage... you either get a battery looking icon or a circle that moves according to how full it is... my OP5 has the percentage labeled inside of the circle icon.
2. You cannot adjust the navigation bar color or style so in most instances it looks awful. The only fix I have at his time is to disable it and use gestures. See these pics:
View attachment 76857 View attachment 76858
(that stupid nav bar is always white, even with the dark theme enabled and no settings to modify it)
3. There is a wonky thing with unlocking that phone that I don't like and maybe it's just a bad habit I developed that bothers me now that it functions differently. There are settings to change how this works but basically I'm used to tapping my screen or pressing power to get to the lock screen, I can check notifications etc without unlocking to the home screen (cool!) If I want to get to the home screen just tap the FP reader and you're in. However on the OP6 if you have face unlock and hit the power button or double tap and it sees your face, BOOM home-screen, you can disable this but then it requires you to press power, or double tap the screen, brings you to the lock screen you can view notifications BUT THEN you have to swipe up if you want to unlock and get to the home screen. I honestly don't know what would make this better, how to fix it or if there even is a reasonable way to "fix" it / do it differently but for now I basically have to angle the phone away from my face if I just want to check notifications. (I'm a whining complainer I KNOW!)
It reads very well and very fast, when I scanned in my FP, I did it at the most comfortable and natural angle that I would day to day unlock it with. I think my finger is at a.... 45ish degree angle when I unlock. If FP unlock is your concern, have no fear, it works perfectly!
Sauce:
See if you get your desired results with Nova Launcher. Nova Launcher right out of the box makes your navigation bar transparent.You cannot adjust the navigation bar color or style so in most instances it looks awful. The only fix I have at his time is to disable it and use gestures.
he said stockHave you tried Nova Launcher? Nova Launcher right out of the box makes your navigation bar transparent. Because I like a black background I placed my Moto X Pure on my bed, camera side down, and took a picture then used the picture as my wall paper. Here is the result.
Sorry for the huge image, but when I chose thumbnail it came out all blurry.
Thanks, I edited my post.he said stock
That's exactly what prevents me from buying another OP phone. I've never cared about having a state of the art camera on my phone.As predicted, the new OP6 is exciting lots of us who don't care about needing a great camera. But with all the issues with OP spyware and other security issues such as storing passwords in plain text, and OP's record on being plain stupid, does this reminder deter anyone now?
Did the navigation bar become and stay transparent after installing Nova?... The only thing I missed was the google now panel, but after installing nova launcher, it became non issue.
What color and config.well I finally got around to ordering it today.
Nice! One suggestion try using the gesture navigation. It take a few days to get used to it, but I really like them now and it has become second nature. Plus you get a cleaner look and a bit more screen backmidnight black 128GB. Got the carbon bumper case and the glass screen protector too. I want to get the wireless ear buds too but I don't think they will be in stock again until the end of the month. I really liked my OP3 and only quite using it because I dropped it so many times over the past 2 years that the camera finally took a crap. I got a used Axon 7 to replace it but it just doesn't feel as snappy as my 3 was
Nice! One suggestion try using the gesture navigation. It take a few days to get used to it, but I really like them now and it has become second nature. Plus you get a cleaner look and a bit more screen back![]()
I think you were lucky more then anything. What case you using or is it naked?Just want to add that I dropped the phone on pavement yesterday from about 4ft. It was a bad fall, I was sure there was gonna be a crack on the screen or back.
Thankfully the phone withstood it like a champ and is working fine so far. Props to O6 for not skimping on build quality.
