One grand to blow
Gimli
Hey guys... after finally building my third computer, I've decided to move onto a laptop. As much as I love my tri-comp setup at home, I need something mobile.
Right now, I have around $1000 to spend on a laptop. I'm not looking to play games on it, or do anything extremely graphics intensive. Currently, I am a video game programmer, so I need a laptop that has a decent amount of ram ( 512 preferably ), decent sized screen ( since I'm going to be staring at it alot), and a decent hard drive size ( preferably 40gb or higher). All it is mainly going to be used for is coding large applications, listening to music, and watching movies/dvds. I would like a laptop with centrino technology so I could take it on the road and have decent battery life. However, I'm not too familiar with the laptop market right now, who is good to buy from, and where to get the best deals.
If anyone knows a place to get what I'm looking for for the price I have, it'd be greatly appreciated thanks.
Toshiba makes a sick laptop, at great prices. I've always been a fan of them, and they are more reliable than the Compaq's, HP's, and Dell's of the world. Dells are crap. IBM Thinkpads are nice but on the high price tip. You most likely won't find a decent Centrino based laptop for $1000, you will most likely get a Celeron or AMD based laptop for that price, or at the most a P4 lappy with little memory and little features like intergrated wireless and a larger hard drive. The AMD based laptops perform nicely and are priced great, but run hotter temps. Toshiba uses only Intel chips. Consider using one with a Transmeta Crusoe chip or theyre new Efficeon. More bang for the buck for an alternative chip.
Hope that helps.
Andrew
agreed. i have a toshiba. very happy with it. very affordable. thats what i suggest looking into.
The Toshiba Tecra line is pretty good. Centrino 1.6, M9 for 2500 Cdn
Heard anything about IBM laptops? I use one from work, and I love it. Most reliable computer I've ever used, laptop or otherwise. A little more expensive, but worth looking in to.
Dell Latitudes are awesome. Look into the D505 with the Centrino package. It would definitely do what you want it to. IBM has always made solid laptops, but I would buy the Dell over the IBM. Toshiba used to be by far the best laptop and my mom has a Satellite S501[?]. However, there is no longer a distinct divisor between the ranks. I would not get HP or Compaq, and strongly recommend the Dell.
The eMachines laptops are nice too - look into those.
i would recommend dell, and sager for note books, not sure if sager has centrino, but they are the damn best notebook on the market. and they are extremely cheap, and still use the same high quality components.
there, now i look inteligent (if i could spell it that is) for when this gets moved to mobile computing
Agreed, i have a Toshiba as well and love the thing. If you look at Compaqs, i've noticed that all the newer Compaq laptop's i've seen are really loud. The fan they use or something is so loud that it drowns out everything around it. That's probably somehting you'd want to take into consideration as well. My Toshiba Satelite is nearly 100% silent. Onlything i can really hear from it is when i put a CD in and it spools up.
Not to thread crap here, but how heavy are the Toshibas and Dells? The IBM I have is fairly light; I can take it pretty much everywhere without any hassle.
I like Fujitsu, Toshiba, and Sager notebooks myself.
Dell Latitudes can get pretty light; I'm not quite as familiar with Toshiba's. I don't do much with the super-portables; I tend more toward the mobile workstation (aka GAMING) books.
I have a dell and I love it. Haven't had one problem with it and the prices for Dells are great.
A little bit of doom and gloom.
The last 2 people I knew who bought dells in the last 6months ended up returning them. A friend bought one, had it replaced twice because it died twice and finally ended up gettign rid of it when the 3rd one died. (over the span of 1.5 months) Another friend who bought the dell had to have the motherbord relpaced, and when that went bad it was also retured. Both bought ibm and are compleatly happy now.
I don't know jack about laptops. But our IT department for the company I work for (33,000 employees) stopped buying Toshiba Laptops about a year ago and switched to HP laptops. There was some quality issues along with the all important pricing issues.
I have a sony, and really enjoy it. Try Sony, Toshiba, or Sager cannot go wrong with any of them.
Buy Toshiba.
Stay the hell away from Dell. My mom bought a pretty nice one from them, and after about three seconds of playing with it, I started to wonder what the hell happened to their design team that had done so well in the early Pentium days. The fan is on the bottom. Put the laptop on your lap, and burn your balls off. Then, I pinched my fingers really hard by opening the LCD screen. The fan is noisy and the plastic is bendable. Just don't bother.
If you can, find an OEM toshiba dealer for an awesome deal.
Originally posted by kovermours
Buy Toshiba.
A lot of laptops have fans on the bottom of them. They even make devices to raise the laptop to allow for better cooling.
Anyways....
Get an IBM. I've had experience personally with several: older models, A series, R series and T series.
I'm typing on my T30 right now. Quality is excellent.
I appreciate the input guys, but has noone looked at the choices I posted yet?
Originally posted by scotmod
Be different, Buy a I-book.
if you want an Apple with any real amount of RAM/processor speed, you'll need more than $1000. I should know, I used to have a Mac laptop. Nice, but sooooo expensive.
Sager is good...they're the same guys who do the Alienware laptops (though obviously much cheaper).
IBMs may be decent, but they look like the style hasn't changed since the '80s...obviously not a major concern, I just think it's funny.
