Hate_Bot said:1 6800GT.
If you want to save some money, an X800XL is also a god choice.
But a 6800GT is better then 2 6600GTs.
Or, you could save up, (your current card is pretty good) and get an R520 or G80 in a few months. Spending alot of money right now (especially when your current card is pretty good )isnt all to bright, with the R520s and G80s coming out in a few months.
BoBo 007 said:
What do you mean?Lajnus said:yes i could do that but i wanna go with pci-e thats the thing
Hate_Bot said:What do you mean?
X800XL is PCI-E
the R520s are going to be PCI-E, ditto for the G80s...
Lajnus said:i mean that i wont be able to use my old 9800pro because im getting a msi k8t neo board
but maybe ill just wait and save some more money for the r520's or the g80's
mavalpha said:I'd go with the 6800GT. If you're even considering SLI, it still leaves one slot free in case you ever want to add a second 68GT as well, or switch over to AMR if/when it catches up to or beats SLI.
Hate_Bot said:like I said, getting a brand new top of the line card right now isnt so smart. With the R520s and the G80s coming around.
Just keep your 9800Pro for now. And save up...
cell_491 said:dont spend alot of money on this generation if your just now getting into it....either find a single 6800gt on ebay for around $300 or get that rosewill x800xl on the egg for $280 because either one of those will kill sli'ed 6600gt's
True they will be 6-700 dollars, but they will also knock the price on the current cards down alot methinksspaceman said:that and the new cards r520 g80 are going to be around 6-700 dolla range. the 6800gt is a good idea for sli. the 800xl-xt is the deal for single slot solutions.![]()
Chris Lakies said:I personally have 2x6600GT's which work great both OC'd to 540/1150mhz. Mid 6,000 3dmark05 score. The problem is right now the drivers aren't that great for SLI. I would go with a 6800GT or if you can afford an Ultra which should last you quite a long time. Then when games come out that use all your power up you can buy another 6800GT or Ultra and by that time they will be fairly cheap and SLI drivers should be sorted. Just make sure you have a good PSU.
kirbyrj said:After looking over that xbitlabs article, I didn't see too many instances of a single 6800GT beating a 6600GT's in SLI even with eye-candy and at 1600x1200 (and that probably with the 66.93 drivers that are ancient). I'd say that overall they are comparable. 2 6600GT's cost $360 or so new. 6800GT in PCI-E costs $374 (cheapest at newegg). Similar performance, similar price. Back when SLI came out, the cheapest 6800GT PCI-E's were $450. Big difference in price between the two.
Either way you look at it, both are going to game pretty well at 1280x1024 which is the native resolution of 17" or 19" LCD's which will probably be pretty common for gaming since there is a $200 difference between them and the 20" Dells which run 1600x1200.
I got the 6600GT's just to see how SLI worked without spending $400+ (at the time) for a single 6800GT. Now when someone I know needs a computer built for them that requires mainstream graphics, I can use my 6600GT's and try something else.
I still think people who bought 1 6800GT with the intention of getting another later are going to find it difficult to match their 1st card to get SLI working properly. Different BIOS, different hardware revisions to cards. If I was going to go SLI, I'd buy two cards at the same time from the same vendor. In some cases, the only way you can afford that is with 6600GT's.
chrisf6969 said:6800GT
faster in many cases, b/c its got the full 256Mb of ram on the card
And you can always upgrade to a 2nd 6800GT later. (later = cheaper & easy upgrade)
Where with the 2x6600GT's you'd have to sell them both & buy 2 x whatever card. (not as easily upgraded)
The X800XL's are another good option,
but I would rather have the 6800GT b/c of sm3.0 for future games, and SLI.
Lajnus said:yes but how good is the x800xl compared to a 6800gt ??
fallguy said:
kirbyrj said:And $100 cheaper![]()
italstal81 said:Don't go with 128-bit memory... If you're going SLI, go 2 x 6800GT (or ULTRA).. SLI just doesn't make sense unless you're going for high end performance.
jacuzz1 said:Thats not accurate. It is a 128 meg card and 256 bit like its older brother and it out performed my 9800xt if you need a reference. A single 6600gt is very formidable indeed when you consider its less than half the cost a 9800xt was and in my experience was more power full
BoBo 007 said:
Rollo said:Actually that is accurate. 128MB of 128bit access 500MHz RAM is the 6600GT spec. I have a 6600GT SLI rig as well as a 6800GT SLI rig, I know of what I speak.
