onboard gigabit interfaces
cugine
Hey do you guys use the onboard nic interfaces on your mobo or do you disable them and install a pci card? Does it impact cpu performance if you use the onboard?
Thanks,
cugine
Thanks,
cugine
I use the onboard on my old Abit KV8 PRo. No issues as it is not a 'soft' nic, but a hardware one. That board is 4 years old. New IP35 Pro for Christmas as a gift.
I'll ditch my Audigy for it finally. Board has firewire too (that I need for my DV Camera.
While onboard may require some CPU utilization, its not enough to warrant a discrete NIC for most desktop applications. I use the onboard LAN on all my home systems. For servers... thats a different story.
I've had no problem ditching an extra NIC for onboard. They're cheap, but waste a PCI slot, and by now, we don't have a lack of CPU power on most machines.
-bZj
Onboard NIC for me. The only time I use a PCI one anymore is when the onboard mysteriously vanishes on me.
Have used the onboard NIC for years now on many different PCs.
Works like a charm.
