So if there is fan on the heat sink air will be pulled off, and if no heat sink pulled on?Megadeth_Guy01 said:On, always, if you're talking about heatsinks.
Very few people do this, it substantially increases temperatures over what most people run.KaptainBlaZzed said:the air is almost always pushed onto the heassink, twords the mobo
My zalman cnps7700-cu pushes air toward the motherboard, I just took off my case door and checked.Oline61 said:Very few people do this, it substantially increases temperatures over what most people run.
This is how your fan should work:
All of those Zalmans, the TT Big Typhoon, etc all pull air away from the mobo/heatsink.
Oline61 said:
I own no BT's, but if you are telling the truth, your BTs are wired incorrectly, and decreasing your cooling performance. I have also never seen a fan with these mysterious "cross supports" either. After looking at many popular fans such as the high performance Deltas, Panaflos, Vantec Stealth, Vantec Tornado, etc I see nothing resembling what you describe as a cross support. In addition having helped a friend install a BT over his 3000+ Winnie I know for a fact there there are none of these "cross supports" on a BT, and that the air rises away from the motherboard. A far more reliable way to look at airflow is this diagram:KaptainBlaZzed said:you are wrong, how many BT's do you have???
look at the fan, Fans always blow the air twords the cross supports that support them.
Do you see any cross supports in that picture.....NO
because they are on the other side of the fan, thus blowing the air onto the HSF.
Oline61 said:
Looking at the fan blades on any of these units, it is quite obvious which way air flows. It's not very complicated.
EDIT: To make it simpler, think of this. The air picks up heat going through the heat sink. If this heated air blew down, towards the motherboard it would increase temperatures, however if it blew out and away from the motherboard, it wouldn't.
Oline61 said:
lets see if you can hold your breath that long...p0intblank said:*Waits for Oline to come back in*
rich1111 said:just try 1 way and see the temp flip it and see that temp i have run both ways my amd is pulling my intell is pushing but tryed both way on them and i got them set up the way the boxes wont
