On-Demand Microsoft SQL Certification Course $99! HAWT?
It magically dropped to $89 while I was at the page.
Yeah, the magical $10 limited time deal. Should go away with in a day.
I'm wondering why this is so cheap. Anyone know SQL?
I've used MySQL, MSSQL, and Oracle and this is probably a worthwhile deal if you wish to learn about relational databases. If you know one, the rest are pretty easy to learn. It all depends what you want to use the database for. If you're running a basic website and need to store some information, SQL is good. If you're looking for big data and high performance, you may wish to focus your efforts on something like hadoop or cassandra. If you stick with SQL though, check out Percona. I've used Percona XtraDB in a production environment and it has really been quite nice. I've had a node go down without interruption in service. Also, the Percona Toolkit (which also works with standard MySQL) is great for gathering information about your database. Hope that helps!
I bit as well.
Been needing to pick up a SQL cert for a while now.
Just FYI, this doesn't buy you a cert, but a series of videos and quizzes. You still need to sign up for and take the Microsoft exam separately. Vision Training is not an MS partner, and doesn't seem to have any physical location presence or web visibility. Don't expect too much here.
Bummer to hear
Either way, I'm signed up. If it helps me to gain some knowledge to help me with attain future certs, I'm down.
IIRC, the tests are something in the neighborhood of $100-200 a pop.
Nope, they are online based.
