Read sth about using this tool to tweat your 6800 NU to an "Ultra"...
Link to download here
http://www.mvktech.net/download.php?view.556
joemama said:Okay, first of all nothing is going to make a 6800nu an Ultra and second......what the hell is that and why should anyone download it?
Not a good idea to flash an ultra bios to a nu (if indeed that's what that is) because the extra pipes are disabled for a reason. The nu also has ddr@2.8ns as opposed to the gddr3 @1.6-2.0 for the Ultra. At best you might be able to do a reversable soft mod to open up the extra pipes..g3no said:arent they using the same chip? if you got really lucky mabe the card would work with all pipelines enabled and at decent speeds
I really don't know but I'm not downloading something who's only description is "1.3"g3no said:ahh ok, i just thought that they might be throwing perfectly good chips into those vanilla 6800s, but with current yeild problems and whatnot, i can see why they wouldnt be doing that at this moment ;D
i was under the assumption though that that program was a softmod, and not a bios flash, but without a 6800 i have no clue for sure
